Cathedral or square port heads?
I thought I did read somewhere that the cathedral port heads were better at generating air velocity at a lower RPM, can anyone validate that?
Interesting article this cathedral head makes more torque below 4000rpm but its not far in front of the square port
Very interesting...
Here's a "clickable" link...
http://www.cpgnation.com/car-craft-l...re-port-heads/
Lme 427ci
TFS 255 cc 12 degree LS3 head
12:1 compression
fast 102 mm intake / tb
248/264 cam
644 hp/580tq
Vs
Tony Mamo 434 ci
Afr 245 cc cathedral port head
11:6 compression
247/251 cam
Fast 102 mm intake/ tb
678 hp/600 ftlb
I know mamo motor has more cubes but not by far (only 7ci difference) but LME motor has more compression.... I have a link to both builds if you guys want to see them for yourself. If you look at lme 427 motor the torque curve does like a hill. It starts low goes up and then slowly back down. Look at mamo 434 motor the torque curve look flat at a pool table and it produces more horsrpower on less compression.
