water pump interchange
Old Dec 19, 2014 | 07:15 AM
garys 68's Avatar
My feeble memory kicked in an I recalled this thread below with measurements.
If that doesn't save enough room for you, the LS2 corvette pump is really flat faced, less of the shaft protruding. You could use one with 1 1/2" spacers (available on ebay). That combo might buy you and additional 1/2 - 1"
https://ls1tech.com/forums/generatio...pump-pics.html
Originally Posted by omc8
Thanks man , I will try that !
Old Dec 23, 2014 | 07:43 PM
omc8's Avatar
Yes, wish I could just get that LS2 pulley and put it on my truck water pump . If Im only going to gain 1/2 inch its not really worth it to me .
Old Dec 24, 2014 | 01:12 AM
joecar's Avatar
Originally Posted by busha61067
I have a 03 lq4 block going in a 2000 Camaro with and will be putting 2000 ls1 car accessories on it. what water pump do I need to go with. part numbers would be nice Thanks!!!
If you have F-car accessories, then at the parts store tell them you have a 2000 Camaro 5.7L and that you need a water pump and thermostat for this;
before you leave the parts store, check that the TS fits all the way into the WP, and that the WP pulley is elongated bell shaped (not flat shaped).
