Throttle/Auto revving problems
Old Dec 3, 2014 | 06:43 PM
z28camarofn's Avatar
Default Throttle/Auto revving problems
Has anyone had a problem when they start their ls1 up, that it automatically revs on its own at idle? I have a 6 speed, and it fluctuates between 1700-2000rpm on its own when I start it up. I tried revving it myself to see if it would fix the problem and it revs up to 3,000 and holds there until I cut the car off. It makes me nervous to drive it in case it gets stuck while driving. Any ideas as to why?
Old Dec 3, 2014 | 07:30 PM
_JB_'s Avatar
Vacuum leaks can cause high idles. Have you worked on the engine lately? Maybe a vacuum hose broke/loose?
Old Dec 7, 2014 | 07:17 AM
No i haven't done any work in a couple years. Someone said it's the idle control valve pretty confidently. do you think that could be it?
Old Dec 12, 2014 | 09:14 PM
trey0153's Avatar
ya more than likely a dirty sensor check iac,tps and maf make sure there clean.
