Fuel Injectors and Rail Compatability :confused:
Old Dec 6, 2014 | 10:14 AM
CORYSTA's Avatar
Default Fuel Injectors and Rail Compatability :confused:
I'm currently working on gathering the needed parts for a project I'm working on.
https://ls1tech.com/forums/generatio...3-heads-4.html
I'm looking to add 243 heads/Cam and a Fast Intake to my DD 02 WS6. Looking to get in the 425 RWHP range. From what I've learned as of late, I'll need to upgrade my injectors for this HP goal. While I'm adding a FAST intake and new injectors I'd like to add a sexy set of FAST fuel rail while I'm at it.
I've seen a lot of good deals on LS2/LS3 Injectors and Rails and would like to pick them up, but I don't know if they'll work on my LS1.
Question: Will LS2/LS3 Injectors/Rails work on my LS1/LS6 or can they be made to work?
Thanks.
Old Dec 7, 2014 | 08:26 AM
CORYSTA's Avatar
Alright, so what about fuel rails? Is it the injector that determines which fuel rails you need, is it the connection to the fuel lines, or .....?
Old Dec 8, 2014 | 01:49 AM
Fry_'s Avatar
If you go with a FAST 102 you have to run LS2/3 fuel rails. A FAST 92 can work with either fuel rails, but I think you have to put spacers on top of LS2 or LS3 injectors if you use them with a LS1 fuel rail. I believe all 3 injectors are different heights. If you go with a FAST 92 you could just have you stock injectors resized by Fuel Injector Connection for $240 and use your stock fuel rail. Stock Fuel rails may not be as sexy but they're $350 cheaper.
Old Dec 8, 2014 | 08:52 AM
CORYSTA's Avatar
Thanks for that! I was thinking about resizing mine, but for that price I can pick up a pair of what I need off the classifieds for that or less. Then I can sell those injectors with my LS6 intake.
