Po106 code need help
Old Dec 24, 2014 | 05:05 PM
white SS 74's Avatar
Default Po106 code need help
I have a stock bolt on 2002 camaro throwing this code replaced map and still get code Running 231/239 on 108 lsa started having issues after rocker arm change ajustable comp 1.75 any ideas
Old Dec 24, 2014 | 05:44 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Check the pigtail for the MAP sensor. I had and fought this for over a month once. The green wire on the male end (wire harness) had actually pulled out. 11 bucks for a new pigtail and never had a problem again.
Old Dec 24, 2014 | 07:48 PM
I'll check it out thanks
Old Dec 24, 2014 | 09:10 PM
Russ K's Avatar
You need to raise the P0106 Error Calculated Max table in the tune. As your idle Map KPA is probably >60, and that exceeds the stock table value. I just make that table higher than the actual Map KPA of the engine.
Russ Kemp
