Cam Sensor
Old Jan 1, 2015 | 12:27 AM
Streetracer09's Avatar
Default Cam Sensor
Been scratching my head on this for a bit. I bought a motor that seems to be a Gen 3. It has a rear Cam sensor, Black 24x crank sensor and Knock sensors in the valley cover.
The guy switched out the cam for an LS9 and I believe he put a different front cover on it with a provision for a cam sensor. Can I plug that and run the rear sensor or do I need to switch over to that sensor in the front for some reason?
I'm stumped.
Old Jan 3, 2015 | 07:19 PM
S10xGN's Avatar
You can if you change the cam back to a gen III, the Gen IV cams do not have a reluctor...
