6.0 flexplate on 5.3 won,t start
Old Jan 14, 2015 | 05:14 PM
74propu's Avatar
Angry 6.0 flexplate on 5.3 won,t start
had to replace th400 trans so I changed from the stock flex plate to a 6.0 flex plate with spacer and arp crank bolts . turned over fine while putting in torque converter bolts no binding not rubbing anywhere .started yesterday with the stock flex plate now it will not start just clicks /bangs into the flex plate and don't spin need help I am lost
Old Jan 14, 2015 | 08:16 PM
S10xGN's Avatar
You're not real clear, are you saying the engine is locked up? Is the "new" flex flat? Is the spacer between the flex and crank?
Old Jan 14, 2015 | 09:41 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Assuming the engine is no locked for some other reason, if the starter worked yesterday and now bangs into the flexplate, something moved around.
Old Jan 19, 2015 | 06:05 AM
74propu's Avatar
pulled the starter out and had it tested it was good tried to shim it it would start 1 time then hang in the flexplate add more shim start 1 more time and hang again pulled it out and put in new starter and all is well starts just fine now
