Ls1 crank sensor mounting bolt
Old Jan 19, 2015 | 09:26 PM
laurentj23's Avatar
Default Ls1 crank sensor mounting bolt
Ok. I tried to search but couldn't find anything. What's the bolt size for this bolt?
Old Jan 19, 2015 | 10:14 PM
Paul Bell's Avatar
That's MISTER MODERATOR
M8 x 1.25 x 20. GM part number 11515756.
Old Jan 20, 2015 | 05:28 AM
laurentj23's Avatar
Awesome thanks paul. If i didnt had it mounted with the bolt, would it prevents the car from starting even though its on there?
Old Jan 21, 2015 | 10:51 AM
laurentj23's Avatar
Another one. How about the thermostat housing bolts?
Old Oct 7, 2015 | 08:49 AM
S10xGN's Avatar
I'm going thru this right now, too long! Bolt bottoms out about 1 thread before touching the bracket. Correct bolt needs to be 15mm long (or just stack some washers under the head)...
