pcv vs. open vent questions
Fast 102mm
Nick Williams 102mm Tb
Valley cover with no vent
Pass valve cover has no vent
Driver valve cover has vent in the rear
I had the stock pcv hooked up when the motor was built, but I was having major oil consumption problems, and it kept blowing the hoses off the driver valve cover and at the pcv valve.
I now have a breather filter on the rear of the driver valve cover, and a breather replacing the oil cap on pass valve cover.
That left the port on the left side of the intake where the pcv valve was, and the port on the throttle body.
I left the pcv on the intake, and put a breather on the pcv. I also put a breather on the throttle body port.
I have had absolutely 0 oil consumption since. Problem is, on cold start it tries to rev back and fourth between 3k and idle for usually 30 seconds or so, and it high idles while I'm moving and idles normal when I come to a stop.
If I have a buddy plug the Tb vent with his finger, it doesn't try to cold start like that as bad.
So should I have the intake and Tb blocked off? Or just the Tb?
Ive done my searching and I've seen tons of setups and tons of ppl arguing them.
My goal is no oil in the intake while still having ventilation.
Are there any real problems with it being just vented over being drawn out by the pcv system?
Any thoughts are appreciated. Thanks guys
Did you try a proper catch can? I assumed you are still running a MAF. Are you?
It occurs to me that if you set up the PCV correctly as indicated above with a catch can, you should keep your engine clean and not have oil in your intake. If you are building so much crankcase pressure that you are blowing the PCV system apart, something is plumbed wrong or you have excessive blow-by..or boost but I don't see that in your sig.
Now if you can get PCV hooked up right with a catch and such, it seems that to overcome the excessive pressure issue you could T off the PCV line or the vent line and put some type of one-way valve there(a PCV of sorts?) that would vent during times of excessive pressure but close up during times of vacuum in the PCV system. Maybe even a different PCV valve with a weaker spring. Haven't thought that all the way though but it would basically be a tiny blow off valve.
Mighty Mouse and RX both already have 1way valve/breather solution, or DIY .
http://www.ws6project.com/user_stor/..._find_part.php
http://www.ws6project.com/user_stor/...cturers_id=353
You can get the RX Performance breather/1 way valve at Colorado Speed.
http://www.coloradospeed.com/rx-perf...7qu1bt93sc8op2
