Ported throttle body problems
Old Mar 8, 2015 | 10:21 PM
kaharvey88's Avatar
Default Ported throttle body problems
Apparently whoever ported the throttle body on my car got a little carried away. They enlarged the area around the blade too much and it was causing a high/searching idle. I'm currently running a borrowed (stock) throttle body from a friend until I decide what to do with mine. Could I fill in the hole in the throttle blade and cure the problem of it getting too much air at idle or should I just spend the cash and get a Nick Williams or something equivalent? Thanks
Old Mar 9, 2015 | 01:51 AM
trey0153's Avatar
Ya I believe the blade is supposed to seal up when closed if there's a gap around it when closed its prob good for a paper weight now,get another one.
Old Mar 10, 2015 | 12:28 PM
kaharvey88's Avatar
So no hope for it even if I fill in the hole in the blade?
Attached Thumbnails Ported throttle body problems-20150308_181016.jpg   Ported throttle body problems-20150308_181058.jpg   Ported throttle body problems-20150308_181030.jpg
Old Mar 10, 2015 | 06:36 PM
farmington's Avatar
you could put a small screw and nut through the hole (temporarily only) to see if it changes for the better. if so it could be welded shut.
Old Mar 11, 2015 | 11:05 AM
omc8's Avatar
From the pictures I dont see a gap. Where do you think air is getting past the blade ?
Old Mar 11, 2015 | 12:51 PM
jig's Avatar
jig
the first and third pic you can see light coming through around the blade..no to take the thread off of the op but when i put a p&p throttle body on i got the ses light that said something about my iac..any way to fix this?
Old Mar 11, 2015 | 01:27 PM
VandykeT/A's Avatar
Take a piece of tape and put over the hole and start it and let it idle (make sure its good tape, masking tape etc) and start it see what happens. If its been cut around the blade its probably junk. If the tape somewhat helps the idle you may have adjust the blade to get the IAC counts back to normal but i would expect it to do some weird things.
Old Mar 12, 2015 | 12:47 PM
kaharvey88's Avatar
Mine would get different codes like P0507 (idle higher than expected), I got one for IAC once, and a few times I would get oxygen sensor codes. Went back to stock throttle body and everything straightened out.
 Michael S. Palmer
Old Mar 12, 2015 | 12:58 PM
kaharvey88's Avatar
I'll try blocking the hole and see what happens. Right now the blade is adjusted to the point that it almost sticks closed from when I was trying to get idle back to normal. What kind of numbers do I need to look for on IAC? What kind of weird things?
Old Mar 12, 2015 | 01:08 PM
gagliano7's Avatar
Between 35-75 iac counts.
Old Mar 14, 2015 | 12:41 PM
VandykeT/A's Avatar
If its not sealing correctly probably intermittent hanging idle, cruise control effect, up and down idle. If you can seal the blade and possibly tune the base running air flow table it may work out. You'll have to seal the blade then adjust the counts, I would shoot for around 40-50. If everything seems ok your probably fine. If not you may have to touch up the tune to make up for it. Make sure you do a tps reset also.
