Alternator Experts: Please Come Inside
Recently, I started having an issue where the voltage would be fine at idle and normal driving but drops as RPMs increases and over 6000, it will drop to as low as 12.2V. I am concerned about the effects to pumps, electronics and especially the 5V circuitry. Buddy of mine believes the high RPMs might have caused the big rotor to fling apart and at high RPMs I am running off the battery. Would like to avoid dishing out $$$ for another, if possible, and it looks like Advance Auto Parts might replace it at no cost. Buddy suggests I try a clutch pulley on the alternator.
Looking for expert opinions on this suggestion or any other recommendations.
TIA,
I assume you have the 2 pin regulator. These are normally controlled by the ECM and have a fail safe mode of about 13.8 volts if there is no ECM signal. IMHO they do not put out enough amperage in that mode and do not properly charge the battery. Over time my battery would go down.
I have a thread where I replaced the 2 pin regulator with the 4 pin version which is not use the ECM for control. Others have done the same. I am about to install it in my car and will make a report.
I hope this is of some help to you. By the way you can also get a AD244 alternator with 145 amps which is a very good one and they normally come with the 4 pin plug. That is another option for you.
