Help! LS1 harness and ecu on 5.3?
Old Mar 19, 2015 | 09:22 AM
snowhunter87's Avatar
Default Help! LS1 harness and ecu on 5.3?
I have a 05 5.3 I picked up for $500 with 60k on it. I have put an ls6 cam, pushrods, springs, ls1 intake, ls2 timing chain, and 60# injectors in it, and boosting it with a 76mm turbo.
My question is for wiring and computer, will an ls1 harness and ecu off an 01 SS camaro (ls1) work with my 5.3?? They have the same rel-wheel count, i plan on running the MAF and O2's. Thoughts?
Old Mar 20, 2015 | 12:35 AM
nobody??
Old Mar 20, 2015 | 03:20 PM
omc8's Avatar
Yeah Ls1 harness and ecm works . If you have and iron block and you are running F -body accessories you need to drill the block to mount alternator .
