HELP!! hp numbers
Old Mar 30, 2015 | 06:07 PM
racecarz28's Avatar
Default HELP!! hp numbers
I have a 2002 Camaro Z28, m6 with 50k miles on her. Lightly modded. She has, comp cam ls 3-bolt cam, Hardened pushrods, Brian tooley dual valve springs, ls2 timing chain, Ngk spark plugs, Texas speed 1-3/4" longtube headers, pacesetter 3 " y pipe, slp axel back loudmouth with tips, slp underdrive pulley, slp air lid with k&n filter, was dyno'd at late model throttle at 367 hp and 382 tq. I'm thinking about putting on some ls6 heads, what do you guys think my numbers will jump to? Thanks for the help.
Old Mar 30, 2015 | 08:04 PM
HCI2000SS's Avatar
What kind if dyno? Even though dyno numbers dont always mean much, those numbers are awfully low for your mods
Old Mar 30, 2015 | 08:24 PM
racecarz28's Avatar
I'm pretty sure it's a dyno jet, I think that's what it is called. I was thinking the same thing. I just bought the car a couple of months ago.... so that was something I was confused about... I figured it should have been pushing at least 390 to 400 hp. But I'm not even sure.
Old Mar 30, 2015 | 08:38 PM
n20transam's Avatar
Do you know what cam is in it?
Old Mar 30, 2015 | 08:40 PM
racecarz28's Avatar
The only info I got from the guy when I bought it, was that it was an ls 3-bolt cam. I'm going to try and talk to the guys that put in the parts to see if they have some of the documents from when they did everything
Old Mar 30, 2015 | 08:44 PM
n20transam's Avatar
Yea, that would help. It could be a real small cam. I would make sure everything is on point with what you have before you add more stuff to the mix. It could already be that way and thats as good as it gets, but its still worth checking into.
