Need advice on intake and injectors
Old Apr 28, 2015 | 08:49 AM
artdelee's Avatar
Default Need advice on intake and injectors
Hello I have built a 2005 lq9 stock bottom end with high volume oil pump, 243 head with TSP springs, trunion upgraded rocker, TSP pushrods, ls7 lifters and trays, TSP 228R cam and 2800 yank converter. This with the matching 4l65e will be going in a 1971 c10 im building. The truck will have 411 gears. This will be a street truck and I dont want to use the truck intake. Im wanting to go with the car style intake and all I hear is get a LS6 intake. So is that what I need, Im not looking for a certain hp number just want what would work the best with what I have. Should I move up to FAST?is it worth the extra cost if so what size. Also with my set up what injectors will i need. I do have headers and will be using the stock fbw throttle body. I have a boydswelding tank with the aeromotive fuel pump. any advice is gladly welcomed. Thanks for your time.
Old Apr 28, 2015 | 08:53 AM
farmington's Avatar
36# or 42# injectors will work for you
Old Apr 28, 2015 | 09:18 AM
artdelee's Avatar
thanks for your reply
Old Apr 28, 2015 | 10:47 AM
HCI2000SS's Avatar
The Fast intake will net you around a 15 hp gain, so only you can determine if it's worth it
