Eastwood tri-flow radiator
I don't see the need for it. The BeCool radiator cured my overheating issues-and it's single pass. And it's a direct bolt-in.
The argument of flow vs temp drop is that if the flow requirements of the engine exceed the flow rate of the radiator during the test then the temp drop of the three passes will not be any more than it would have been with another radiator of the same flow rate and same efficiency regardless of number of passes.
This radiator is a gimmick. I've never run anything more than a dual core single pass radiator in any of my cars, and I have had some high power road course type cars.
