Professional Products PowerForce+Plus Damper
Old May 4, 2015 | 08:31 AM
Z28boy2000's Avatar
Default Professional Products PowerForce+Plus Damper
Anyone running the Professional Products PowerForce+Plus Damper? My new motor setup has one. Ever since I finished the build and swap into my car I have noticed my voltage is lower than normal. I went to start my car after a 10 min drive at low speeds/low rpm's and the battery was dead. Not sure if I need a different alternator pulley for this setup? I have spent a few hours looking around and haven't seen anything indicating that this might be the case but I figure it cant hurt to ask
Old May 4, 2015 | 10:39 AM
kinglt-1's Avatar
Well is it under driven or standard?
Old May 4, 2015 | 11:10 AM
Z28boy2000's Avatar
Website says 7.5" which I believe is the standard diameter. Just trying to check anything possible that could be causing the issue.
