Do I need this?
Old May 12, 2015 | 06:05 PM
wayland1985's Avatar
Default Do I need this?
I'm tearing the motor down for a h/c install, and may have gone a little too quickly. I lost track of a few of the vacuum hoses. I think they all have to do with the AIR system (which I think I'm removing), but I'm unsure:
There's a module on the driver's side of the intake that accepts two hoses: I'm not sure if this is just for the AIR system or not. If it's only AIR, can I take it off?
Old May 12, 2015 | 06:11 PM
kinglt-1's Avatar
air injection solenoid...yes you can delete it. The code will need turned off in the PCM.
Old May 12, 2015 | 06:18 PM
What would you plug that vacuum line coming off the T (out of the back of the intake) with?
Old May 13, 2015 | 07:58 AM
kinglt-1's Avatar
A rubber end cap and a zip tie.
