Clutch Master bleed (master in car)
It'll take a few reservoirs full to get the air out.
Still a stock master? If its adjustable then lengthen the rod to maximum stroke (giggetty) to get all the air pockets.
What was described above is basically bench-bleeding the master in the car. If that does not work, the master probably needs to be replaced. 90% probability that's what you'll end up having to do.
