Vacuum pump?
just read a ridiculous thread (unhealthy and useless debate) about breathers on the pcv port and oil filler valve. Instead of all of this, would a simple vacuum pump do the same thing as the PCV? I'm thinking in theory it would do better than bypass air. Then you could route a tube outboard of the engine compartment to eliminate any oil back into the intake. Could also route into a vented catch can, for the hippies sake. Can I get some experts to approve the theory here?
Deadhead vac pump will not draw out any air (forget hydroboost pumps and similar systems).
It has to draw enough air with vac but not too much. No secret recipes.
Header Collectors are a fantastic vac source and they pull dirty air into dirty exhaust. Hippies can kiss my fossil fuel burning ***.
Clean air MUST enter the crankcase from a smaller port then dirty air is exiting. This will create vac conditions in the case and draw out blowby. A small breather filter fits over the ports and gives vac source some restriction.
PCV is still the cleanest and most efficient system.
Anyways sounds like you want to read up on CRANKCASE EVACUATION. Plenty of ways to get the job done but there are considerations.
http://www.summitracing.com/search/p...uation-systems
The ONLY reasons I would suggest ditching PCV system are 1. boost setup does not use filter to create strong vac source. 2. motor needs every octane point possible (oil vapor decreases effective octane rating). 3. race cam does not produce manifold vac.
