Re-torque header bolts??
Old Jun 7, 2004 | 04:56 PM
Camaro SS 2002's Avatar
Default Re-torque header bolts??
It's been about 2 weeks since my LT install and think I may have a small leak. I want to tighthen up the header bolts again, because I know they can expand after a few heat cycles. Do they have to be re-torqued to a certain spec? Thanks...
FYI, I re-used the stock bolts as suggested.
Old Jun 7, 2004 | 05:10 PM
hourang's Avatar
should be 18ft-lbs. they probably havent come loose if you torqued them right in the first place.
Old Jun 7, 2004 | 08:51 PM
JamRWS6's Avatar
You could always buy some Stage 8 lockers and not worry about it again.
Old Jun 8, 2004 | 01:22 PM
Two weeks of driving after the LT install, my mechanic said the header bolts are still nice and tight.
