electric cutout questions
1) It looks to me like it may leak a bit at the exhaust plate. Does it?
2) Does the the cutout know when its open to the optimal setting (perfectly horizontal), then fully closed, or is this something I should 'time' myself?
thanks
its just because you are holding the button and overtorquing the motor...so when you release the button switch the motor spins backwards a bit...
try tapping the switch to close it and you'll see what i mean
