Air Pump Delete Question
Old Oct 4, 2015 | 09:24 AM
Mike TA's Avatar
Default Air Pump Delete Question
I am removing the airpump from my 02 TA. I believe these 2 lines went to the air pump system. If I recall one goes to the back of the intake and the other ran to a solenoid of some type that was mounted to the factory intake ( I think). Since I have pulled the pump can I just cut these off and cap the fitting on the back of the intake? I can't see what they run to on the other end because they are tied in with the wide harness.
Just want to double check before I start hacking things up. Thanks
These lines run back into the wiring harness
Old Oct 4, 2015 | 08:25 PM
Mike TA's Avatar
TTT. Anyone got anything on this?
Old Oct 5, 2015 | 12:13 PM
Burken01's Avatar
Yes delete it and cap it off at the Intake manifold next to the map sensor
Here's a pic to show every component.
Old Oct 5, 2015 | 06:04 PM
Mike TA's Avatar
You sir, are a scholar and a gentleman. Thank you.
Old Oct 10, 2015 | 08:43 PM
Sabohead's Avatar
I'm going to look at my system. I had them "remove/delete" my air pump when I had headers installed. Hmm. Thanks for the picture! Great instruction to to follow
