Bad cam position sensor sympotoms
for the bank 2 issue after you fix then cam sensor I would first clean the maf and see what that does. then monitor the o2 voltage with a scanner to see if its switching quickly. if it does then I would start spraying some carb cleaner around the tb, intake gaskets etc to check for a vacuum leak. if that fails check for any major exhaust leaks near the front o2 sensor and see if any fresh air could be hitting the sensor. if all that checks out I would turn to the o2 sensor itself or a possible sticking injector. if the car sat for a long time the injector would be one of the first things I checked.
