02 sensor replacement
Old Jun 9, 2004 | 04:22 PM
Dmoney's Avatar
Default 02 sensor replacement
Is it worth changing out the sensors. I'm not throwing any codes. I'm just wondering if they need to be replaced at any given time.
Old Jun 9, 2004 | 05:19 PM
davered00ss's Avatar
Moderator
They are about $60 ea. and 4 @ $60 is $240.............Up to you, but they will throw a code when they go bad. If you do change them only do the front 2, use sims or ls1 edit out the rear.
Old Jun 9, 2004 | 05:20 PM
T/A Medic's Avatar
unless you use atap or efilive and find them acting lazy... slow to react etc... i wouldnt tossem till you started throwing codes or running poorly...
but if you do check out Denso O2s awesome products.
