UUC LSx Lightweight Flywheel question
I know I have seen posts previusly where forum members have used the UUC flywheel so I am hoping someone out there may be able to give me some info I have not been able to get from UUC.
I purchased a UUC LSx flywheel privately that had never been installed for my BMW LSx swap. When I tried to mate my T56 pressure plate to it the alignment pins are different. So I reached out to UUC with the hand scribed part number on the flywheel. First leeter is hard to make out but in corispondence with UUC it appears to be GMU-5557. So far they have not been able to provide any other info.
What I am hoping is someone out there can tell me the application (and maybe even the install guide) it was designed for so I can get the correct parts.
thank you
The flywheel is actually a LS unit that UUC made in limited quantities. Unfortunately they are having a hard time finding any information on it. All I know right now is the crank bolts are same but the alignment pins are not the same as the F-body pressure plate I have. So I was hoping someone out there might recognize the part number so I know what pressure plate and clutch to buy.
Thanks everyone
