crank bolt
Old Jun 12, 2004 | 05:13 PM
more carbon's Avatar
Default crank bolt
latest hp chev mag says this bolt is not tty bolt ,looks like you can reuse these bolts. or can you????
Old Jun 12, 2004 | 05:22 PM
Ferocity02's Avatar
You can, I and many others would advise against re-using them. Just go to the dealer and pick up a couple.
Old Jun 12, 2004 | 07:42 PM
jrp's Avatar
jrp
SN95 Director
the bolt is TTY. Ferocity is right, you can re-use it but i'd only suggest that option to get you out of a tight fix while order/buy a new one.
magazines are not 100% and are often typo's or flat out wrong info.
Old Jun 12, 2004 | 10:01 PM
Default the bolt????
car craft with Derek Real and Mike Morgan [Morgan Motorsports] say this is not a tty bolt by design.in the " spring 2004 page 55 "tells the story.this bolt has got a lot of press over time, but what is the real story????
Old Jun 13, 2004 | 01:11 AM
Ferocity02's Avatar
The real story is that you use them once. Sure, if you re-use it there is a 0.23% chance it will fail, but I wouldn't risk it. Torqueing them to 240 ft/lbs stretches the bolt out a small bit. If consistantly removed and re-torqued, it can even break the bolt. Just go to the dealer and pick up a couple. Or you can get some from out sponsors.
Old Jun 13, 2004 | 01:48 AM
felton316's Avatar
Just spend the money and get the ARP crank bolt.
Old Jun 13, 2004 | 12:08 PM
2001CamaroGuy's Avatar
....$25 (vs. $6 for the stock one) and you have a bolt that is stronger, longer (easier to install pulleys), and can be used over and over again
