Ls1 220 as cast tfs
Old Jan 29, 2016 | 07:55 PM
onefast ls1's Avatar
Default Ls1 220 as cast tfs
Do I have to upgrade my rockers or can I keep stock ones?
Old Jan 29, 2016 | 08:11 PM
Kingc8r's Avatar
If you got powdered metal guides you can use stock rockers, if you didn't then you need to upgrade your rockers.
Just make sure you break or grind off the little tabs on the bottom of the stock rocker pedestals before you install them if you don't then the base wont sit flat on the mounting surface and can/will cause issues in the future
Old Jan 29, 2016 | 09:24 PM
Thanks who makes a good reliable pm guides?
Old Jan 29, 2016 | 09:34 PM
one fast zo6's Avatar
TEA can help
Old Jan 30, 2016 | 06:49 PM
Kingc8r's Avatar
Originally Posted by one fast zo6
TEA can help
This.
Basically TEA offers them or you can buy heads through their vendors. If yours don't have them I'm guessing you'll have to send them to TEA unless there's a machine shop near you that can do the work.
Old Jan 30, 2016 | 08:39 PM
bbond105's Avatar
TEA did mine.
Old Jan 31, 2016 | 03:35 PM
KCS's Avatar
KCS
Moderator
TFS makes them. They come in the 205cc heads but can be added I got he other heads, like the 220cc heads. Part Number TFS-30600252.
