Ecm and throttle pedal
Old Feb 18, 2016 | 07:29 PM
Streetrod don's Avatar
Default Ecm and throttle pedal
I have just built an LQ4 for installation in a 53 pickup. LS3 heads, intake , and throttle body. 4L80 transmission. What ecm and pedal is compatible and who has the best deal on an engine harness? Thanks, Don
Old Feb 19, 2016 | 07:57 AM
garys 68's Avatar
You might post this in the conversion section.
Guessing you've got a 24X reluctor motor that you're trying to get to work with a 58x motor TB.
You might consider an aftermarket cable TB and go with a 411 ecu and standard 98-02 harness. Very common and inexpensive.
