Oil catch can... which one to get?
it is fine to have confidence in your product but it is not 'independent third party results' in any stretch of the imagination (as it is made to appear)... so at a minimum take it with a grain of salt.
i am too busy filling orders to pull tricks like that, but I am designing a test rig that will be able to test anyones can in several key areas of performance, and do it all on video. open to suggestions!
Mighty Mouse setup:
-Won't have increased crank case pressure and blow off my rear main seal
-Doesn't smell horrible once I pull it into my garage causing me to have to leave my garage door open for hours
-Proper PCV functionality
-Doesn't look like home made **** under the engine bay
-You can keep ls1 valley cover rather than having to swap it for an ls6
Mighty Mouse was the way to go on my street car setup. I scrapped the whole DIY idea.
