Dorman 615-183X intake
it's not a true A to B test since I put a lil baby cam in at the same time, but considering how much fuel I had to add in the midrange of the VE table I'd say it's worth the hassles to get it to run.
I am not really impressed with the coarse thread screws into plastic...and I had to use epoxy to keep it from developing a vacuum leak in the rear. But hey it's cheap and flows pretty good.
Would not consider it for a boosted application though.
on locktites website it appears a cyanoacrylic gets the best bond on PA's
scroll to page 36 in this pdf link
https://www.ellsworth.com/globalasse...ic-bonding.pdf
We have a full team of Certified Technicians on staff at our HQ in PA. If you are having trouble with the manifold you can call them for help. 215-997-1800
Use a mild LS1 or LS6 to recreate a typical situation.
Use a mild LS1 or LS6 to recreate a typical situation.[/QUO
Its important to note that Dorman develops these Intake Manifolds as OEM replacement parts - not performance. Any modification that customers do after purchase to alter the flow of the manifold is on them.
Manufacturing
Substantially all of our products are manufactured by third parties. Because numerous manufacturers are available to manufacture our products, we are not dependent upon the services of any one manufacturer or any small group of them. No one manufacturer supplies more than 10% of our products. In fiscal 2016, as a percentage of our total dollar volume of purchases, approximately 23% of our products were purchased from various suppliers throughout the United States and the balance of our products were purchased directly from vendors in a variety of foreign countries.
And let's not forget the 16,000 sq. ft. Dorman office in Shanghai, China. Now, this intake should be made in the USA according to the Dorman website but probably not by Dorman.
If a slight modification can reap benefits without compromising the structural integrity of the part, then so be it, even if the warranty is voided.
Thanks for clearing that up. Can you say whether Dorman and Super Auto intakes are manufactured by the same company?
From Dorman's 10-K SEC filing:
Manufacturing
nah it was leaking. verifiable in the old school manner with carb cleaner.
I would not use it in a boosted application.
Now what I think dorman did here was add this ramp to the port to add a restriction so it doesn't fully copy the fast 90 base. Dorman owns the rights to the fast base mold but probably can't copy it fully. Not to mention degrading its performance makes it a stock replacement more than a performance replacement. So dorman makes a large plenum long runner intake that shares nothing with a stock truck intake, looks identical almost externally to a fast truck intake and uses a copy of the fast base but adds the ramp restriction to the base. Now for reasons stated before dorman did this to cover there *** per say but more importantly if you fix what they did on purpose you could have a solid intake. Remove the performance robbing second swirl ramp and see what you get. I'm sure most of us will be surprised.
Dorman, nice try!
I will be gluing mine together like truck Doug and then boosting it to 10psi over my stock intake. However I won't be getting it Dyno tested unless someone wants to pay for it. Otherwise I'm happy to share my logs and injector duty cycles with the forum after I do the swap. You can calculate hp via rpm, cuin, fuel flow etc.
I got my real dorman like 6 months ago from summit racing.
care to comment?
My dorman intake did the same thing when torqued down, evident from blow by/pcv oils seeping from between the intake halves. No "apparent" vac leaks.
