Steam tube/cross over setup question...
I will be installing L92 heads and LS3 intake on a LQ4 short block I just picked up.
What steam tubes do I use (fit under LS3 intake)? Valley cover is currently plugged (no knock sensors) due to engine was set up as a carb set up in a fox-body and he only had front tubes on the heads that we removed. I have another valley cover w/knock sensors and crossover tubes that I will be removing from my 98 LS1.
What is my best/easiest setup? Thanks,
It will be going in this..https://ls1tech.com/forums/generatio...ld-thread.html.
__________________
