TPS issues HIGH idle
Old Apr 18, 2016 | 01:23 PM
Unertl42's Avatar
Default TPS issues HIGH idle
I just took the SS out of storage and am having some issues. With the TPS plugged in, the throttle will shoot to 3000+ RPM, but when it is unplugged, the idle will go back down to ~1100 RPM. With it unplugged, the rpms will hang after accelerating for a few seconds. This is driving me crazy, as I just want to go for a joy ride after a long winter. Anyone have experience with a similar problem? I don't want to just start throwing parts at the issue to see if it will go away.
Old Apr 19, 2016 | 04:17 PM
01ssreda4's Avatar
If you dont wanna throw parts at it then you need to test the tps. With a multimeter, get 12+ from the battery and probe the purple wire of the tps with the meters ground. Key on engine off. Rotate the throttle by hand. Reading should show around .75v + at idle and 4.60v + at wot.
