Best Muffler To Get???
Old Jun 16, 2004 | 12:19 AM
mean00SS's Avatar
Default Best Muffler To Get???
right now i have the slp dual dual exhaust its great just want something that will make it sound better, any ideas how that new borla xr 1 or whatever.
thanks
Old Jun 16, 2004 | 12:26 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
ls1sounds.com
Old Jun 16, 2004 | 01:05 AM
LS1LT1's Avatar
Thumbs up
Keep the D/D (it's a very good exhaust) and get a cut out.
Old Jun 16, 2004 | 02:18 PM
mean00SS's Avatar
any other ideas
Old Jun 16, 2004 | 02:26 PM
2_wacko's Avatar
Get GMMG or True Duals with the Borla XR1's.
Old Jun 16, 2004 | 02:27 PM
Just Floor It's Avatar
I have a great post that shows flow vs. HP its a great comparison....Let me go find it...
Old Jun 16, 2004 | 02:29 PM
OK Heres the flow of some:
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
slik98z's Avatar
long tubes, off road y pipe, cut out, keep the Slp DD.
Long tubes, orx pipe, borla xr1 mufflers dumped (true duals).
You could get the hooker muffler to replace the slp dd muffler, but it will sound quieter at idle, great sounding muffler at WOT though.
Your best bang for the buck sound and performance wise will be the cut out. If you can't afford lt's, just get the cut out. The another muffler could probably be found for relatively cheap. just keep looking, browse ls1sounds.com see if you like something there.
and ill get this one out of the way with for JRP, when you find some different mufflers you wanna know more about the search button at the top is your friend.
Good luck
Travis
Old Jun 16, 2004 | 02:31 PM
Heres HP/Noise Level:
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
Old Aug 20, 2004 | 01:39 AM
2MuchRiceMakesMeSick's Avatar
Thats good stuff man. Where did you get that?
Old Aug 20, 2004 | 01:50 AM
Pro Stock John posted it awhile back...
Old Aug 20, 2004 | 07:22 AM
!LS1 11 Second Club
I used that list to go from Flowtech Afterburners To Magnaflow 4x9 Ovals and the results were accurate. I was looking to quiet things down and things did quiet down.
