Gmc 6.0 hard starting
Old Apr 21, 2016 | 05:56 PM
heavychevy123's Avatar
Default Gmc 6.0 hard starting
Hey guys I have a 2003 gmc Sierra 6.0 3/4 ton. I recently did a tune up completely fluid change plugs and wires air filter and a mass air flow sensor. Drove it around the block ran fine then the next morning I had some issues with starting either long cranks or it will start and stumble for a second then idel right about 1000 but after mabey 15 seconds it all goes away and runs fine I'm at a complete loss any ideas.
Old Apr 21, 2016 | 06:14 PM
fbody4everyone's Avatar
id check fuel pressure asap
Old Apr 21, 2016 | 08:03 PM
Thanks for the tip I'll let you know what I find
Old Apr 21, 2016 | 08:23 PM
conan's Avatar
Have you gone back and rechecked all the plug wires to see if they are all snapped on the plugs and coils tight ? Fuel pressure is another good one to check as said above. Also any codes or SES light ?
