A.I.R. removed
Old May 19, 2016 | 08:44 PM
LS1121's Avatar
Default A.I.R. removed
I removed the AIR pump and all of the hoses that go with it. It started throwing codes immediately so I took it to a tuner and he fixed it so there are no more codes coming up however.........when I start the car it idles at around 800 rpm's and as soon as it put the car in drive the idle jumps up to 1400 rpm's and will stay like that until the car warms up then it will idle at 800 rpm's until it gets cold again then it is the same routine. Did I miss something?
Old May 19, 2016 | 09:45 PM
conan's Avatar
Vacuum leak ? Did you do any thing to the solenoid on the driver side of the intake ? Cap off the Vac hose ?
Old May 20, 2016 | 08:35 AM
LS1121's Avatar
solenoid?? not sure about that, can you explain this a little more and I will go outside and check. Thank You.
Old May 20, 2016 | 08:47 AM
Eric Trujillo's Avatar
Mine is doing the exact same thing, except I haven't removed the A.I.R pump. I'm supposed to remove it tomorrow, so I'll report on how it does, along with the EGR.
