New TPS sensor needed?
New TPS?
New Holley 90mm EFI TB?
It's got a fast 92, 92mm Nitrious outlet plate, and a PTM 92mm TB on it now. I guess I'll first try a new TPS and if that don't work, go with the Holley?
Surely I'm not the only one that's had this problem.....someone chime in.
Unplug TPS
Key on for 5 seconds
Key off
Plug back in TPS
and then check the reading. If it is still not correct then the sensor is going out. Mine has correct voltage but threw codes and reads % incorrectly, so I will be replacing mine.
Unplug TPS
Key off
Plug back in TPS
