i have to start 89 ls1 with screwdriver
Old May 30, 2016 | 09:21 AM
Tanmanls1's Avatar
Default i have to start 89 ls1 with screwdriver
Ok I put a screwdriver across the lugs of the selonoid on the starter and it fired up. What is making me have to do that and what do I need to fix? Thank you
Old May 30, 2016 | 09:37 AM
LLLosingit's Avatar
That's not an easy question to answer with the little information you provided. Could have many causes. In a nutshell, Your not getting switched power to the solenoid. Could be wired wrong could be a bad switch could be lots of things.
Old May 30, 2016 | 09:42 AM
Tanmanls1's Avatar
ok thank you. I'll try to provide some more info. The car was running great then I drove it up a drive way and something scraped the bottom and it just started clicking after that. It just clicks, then I put a screw driver across the selonoid lugs the two big ones and it fired right up
Old May 30, 2016 | 01:25 PM
LLLosingit's Avatar
If it solenoid clicks when you try to start it but doesn't turn over yet starts when you bypass the solenoid by crossing the lugs then I would assume the solenoid is bad. Most auto parts stores can test it if you take the starter to them.
