ARP balancer bolt torque...
Old Jun 18, 2004 | 01:50 PM
mean02Z28's Avatar
Default ARP balancer bolt torque...
I just got off the phone with ARP with a question regarding the torque of their 234-2503 balancer bolt. Apparently, it was recommended to tighten the bolt to 110 lb-ft with ARP assembly lube or 140 lb-ft with SAE 30 oil. Then recently, someone’s bolt and balancer fell off with those torque specs, and today, ARP re-adjusted those specs to 196 lb-ft with ARP assembly lube or 247 lb-ft with SAE 30 oil.
My question is, when I install my new March balancer, should I torque the old GM bolt to 240 lb-ft, to seat the balancer, then remove the bolt, and install the ARP bolt at 196 lb-ft with ARP assembly lube?
The guy also said I can use either ARP assembly lube or blue loc-tite on the threads of the bolt. One is an oil, the other is a thread-locker. Does this make sense? Which would be the better of the two to use?
Everything I said I hope seems pretty strait forward, but can anyone verify this for me? The guy I spoke with was somewhat impatient and confusing to understand.
Thanks,
Chris
Old Jun 18, 2004 | 01:54 PM
2xLS1's Avatar
If you can't believe the rep for the company that makes the bolt, who are you supposed to believe. I don't understand customer service reps acting like that. If they are that annoyed doing their job, they should get another one.
Old Jun 20, 2004 | 01:04 AM
mean02Z28's Avatar
I agree. Anyone else care to chime in about the torque specs?
Old Jun 20, 2004 | 07:44 AM
smokin' joe 00 ss's Avatar
When I put my ASP pulley on last year I used the ARP pulley bolt and the instructions with the bolt said to use their lube on the threads and under the head of the bolt and torque it to 240 ftlbs.
Old Jun 20, 2004 | 09:40 AM
Quick 99's Avatar
dont use the thread locker, i dont think arp reccomends it either, use the factory bolt to seat the balancer then take it out and torque down the arp one.
