Down on Power After Head Intake Swap
I just measured temps at the exhaust header. I could not perceive a big difference bank to bank when idling. All were about 230F 5/6 were about 250F but I think that is just because of tight packaging there. I would expect the difference would be quite noticeable if a cylinder had an issue. Anyone know how much difference is significant?
Seems to be hissing from the back on the intake, I may have a vacuum leak. Vacuum is 12 at idle. I'll likely pull the plugs, pull the intake and pull the valve covers. If no trouble found I'll head to a experienced tuner.
A leak
Biggest difference during my test drive was mid-range grunt. Guess I gotta hit the track again.
Two loose plugs was the issue, car was running great. I found out the hard way that I must have had a leak between the injectors and the intake as well.
My car is always garage kept. This weekend it was outside and rained very hard. I have noticed when I wash the car the cowl leaks water right onto the engine. So, when it rained very hard right onto my engine rain water leaked into the #6 cylinder through the lower injector o-ring. When I went to start the car the next day it hydro-locked that cylinder and destroyed the starter. Tonight I pulled the plugs and it still won't turn over. I think I have broken a piston. I'm ready to pull the head, tomorrow... SUCK
Pulled it apart last night and the piston is fine. The rod must be bent cause TDC is lower than it should be and the engine won't rotate a full cycle, the rod must be hitting something. If I bent a rod seems like the force was pretty extreme and I may have damaged something else that may not be possible to see.
So I'm just weighing my options right now.
The two loose spark plugs does explain a lot - and probably was responsible for being 80 down on power. Shame you never really got to measure it.
