Bad fuel smell in cab
I have a 5.3 with a ls6 intake in my 64 El Camino daily driver and have ran this for about 8 month's with no issues till now. I started getting a MAS flt around a month ago and started getting a gas smell in the cab on hot days no traces of smell when cooler till last night it was unbearable. If I was not speeding up the smell would dissipate if accelerating I was getting gassed bad. The evap set up is a catch can system with a return line back to the TB. I looked for a sign of leakage but found nothing. The plug at the back of the intake with the intake manifold pressure sensor does rotate freely loose dont know if this might be where the smell can come from. Is it possible one intake gasket to head failed.
Sniffing around with my nose I checked the air filter no fuel smell at the TB I did get fuel smell but Im sure thats normal. I also visually inspected each injector looking for fuel leak signs and all looked ok.
Any hep or ideas are appreciated TIA
Ill get under the car tomorrow to look for any leaks and probably replace the hose completely.
