who here has true duals and is lowered?
Old Jun 19, 2004 | 08:09 AM
slik98z's Avatar
Default who here has true duals and is lowered?
I need to see some pics of peoples cars that have true duals dumped and are lowered about the same as the eibach pro kit (which ithink is 1.2 inches).
i gotta make sure im gonna have enough room for my ****.
Thanks fellas.
Travis
Old Jun 19, 2004 | 06:21 PM
Z28Venom's Avatar
do a search for SSONYOURSIX... I believe he has true duals with xr-1 mufflers and is lowered also..
Old Jun 19, 2004 | 07:29 PM
deviate42's Avatar
your best bet is to go with a 2.5in setup. Should give you plenty of room. 3" may be too close
Old Jun 19, 2004 | 07:44 PM
strippedSS's Avatar
Default 1.5 drop
Old Jun 19, 2004 | 08:54 PM
Fulton 1's Avatar
Here's my setup with 3" true duals and Hypercoils which is darn near an identical drop to Prokits (I originally had Prokits and replaced them with Hypercoils)
This is how it compares to the Loudmouth setup I had previously:
Old Jun 19, 2004 | 09:05 PM
exodus's Avatar
holy crap!!!
exodus's Avatar
don't think I will be lowering!
Old Jun 20, 2004 | 12:13 AM
slik98z's Avatar
how often does your car see regular street driving? a beer can is what 2maybe 3 inches in diameter...seems kind of low. Ill probably be going with the tsp rumbler x true duals. right now i have worse clearance than yours with a 2.5 inch set up only because the person who put it in didn't know what the **** they were doing. I wanna lower the car cause i gotta get rid of some wheel gap with the 10 spokes i have...it just looks horrid. im hoping the prokit wont drop me too much.
I never go to places with speed bumps, only road i might have trouble is the one to my girlfriends place which is gravel but it is well taken care of. do you think id be ok with a 3 inch set up?
Also i gotta cut about a half inch off my header collectors to fix the **** up the guy made (he just welded 2.5 inch piping right to teh 3 inch collector, just looks shitty and has a slight leak now), will i have enough room to atleast but the x pipe to the header collectors os i can weld them on? i dont really need a complete slip fit if i can but them close enough to put a clamp around it and weld that on. Thanks for the pics thats what i needed.
Travis
Old Jun 21, 2004 | 02:18 AM
AZ Power & Sound's Avatar
My car is MUCH lower then even a sportline kit (due to crap sagging eibachs that I have gone through 4 sets of) and I dont scrape with my XR1s ever...
Old Jun 21, 2004 | 08:34 AM
Fulton 1's Avatar
Yeah, its pretty low, but not really any lower than the Loudmouth I had before - that was my purpose for including that picture. The car is not a daily driver so its no big deal to me. Actually my previous setup used a 2.5" Y-pipe with RT bullet cats located just behind the header collectors and I would scrape those once in a while. The bullets in my dual setup, however, are actually less conducive to scraping since they're located roughly between the rear wheels. That way as the wheels go over a speed bump for example the bullets go over too. That's a better situation than having something between the front and rear wheels. I'm pretty careful, but I have yet to scrape the duals on anything.
There's just not much room under these cars without hammering the floorpan. Besides, I've been driving lowered vehicles for almost 20 years, so I've developed all kinds of habits to avoid bottoming out on stuff anyway
Old Jul 2, 2004 | 09:27 PM
2w0s060's Avatar
Anyone running a DSL with a true dual set up...if so what loop?
Old Jul 2, 2004 | 09:41 PM
Fulton 1's Avatar
Check my pic of the X above, I'm using a Lakewood (its painted red for more horsepower ).
Old Jul 2, 2004 | 10:39 PM
LG Motorsports loop... fits the best that ive personally seen out here with TONS of clearance
