Return spring
Old Jul 27, 2016 | 11:56 PM
mngoos's Avatar
Default Return spring
OK when I bought my car someone had done the the bump stop MOD on the throttle body but they had hit the return spring is there a way to replace it ?
Old Jul 28, 2016 | 07:33 AM
98cherrySS's Avatar
Yeah, unscrew & remove the throttle blade (2 torx head screws I think). Pull the TPS and then the shaft should slide out. May require a little effort. You can then remove R & R the spring.
Old Jul 29, 2016 | 12:00 AM
mngoos's Avatar
OK where can I get a replacement spring ? Part number ?
