Guys Help!
Old Jun 19, 2004 | 12:55 PM
99CamaroSS's Avatar
Default Guys Help!
how do i know if i'm cross threading a bolt!? The number 5 back from the front...(bolt) on the passenger side manifold is real tight going in...i have all other bolts threaded in but this one is bein a B*tch what now??
Old Jun 19, 2004 | 01:22 PM
davered00ss's Avatar
Moderator
Remove it, clean the threads, use some never seize, and retry by hand first. If you can not thread it some by hand there is something wrong. You may have to clean the threads on the bolt as well as in the hole, with a tap.
Old Jun 19, 2004 | 01:23 PM
Moderator
And also, you may need to use washers on the header bolts so they do not bottom out. The stock manifolds are thicker than the headers so the bolts are too long for the headers.
