vacuum hose help
Old Aug 3, 2016 | 11:43 AM
lilrobo's Avatar
Default vacuum hose help
got my new tune installed and it wont idle , i check the intake with carb cleaner and sprayed it around he base and some fitting no change , i can keep it running by holding the gas pedal a tad bit , let off it dies , i am thinking i may have a vac issue here are some pics
1st one is looking at rear of intake this hose is plugged off temp its close to MAP sensor dont know were its goes
2nd pic is of the pass side its capped off als well its on the bottom of intake
3rd pic is on the intake too it runs back to the drivers side valve cover
4 th pic is on the TB it runs to the p[*** side valve cover
so there is 3 ports i am asking about 2 on intake and 1 on TB ,,
thanks
File Type: jpg
