LQ4 Bracket Motor Timing question
Old Aug 30, 2016 | 09:27 PM
LS-Vega's Avatar
Default LQ4 Bracket Motor Timing question
Guys, I use a 2001 LQ4 for my bracket motor, I have stock 317 heads, Texas Speed MS4 Cam/Springs, Holley Intake (good to 7200 rpm), 650 Holley, MSD6010, 1 3/4" headers... I launch the car on the trans brake at 4900 rpm, shift at 6800, trap through the 1/4 mile 6600. Looking for a ball park timing setting, Idle rpm is 800, have set at 18 degrees, ramping timing up to 30 degrees through 7000 after 4000 rpm...any feed back? Thank You
