99 LS1 Camaro No Start
Old Sep 6, 2016 | 07:45 PM
shizzle24's Avatar
Default 99 LS1 Camaro No Start
I swapped an ls1 from a 2000 camaro into my 99 camaro. I took the pcm, computer, wiring harness, body harness, steering column from the 2000 and put into my 1999. I am getting a no start. I'm using keys from the 2000 and tried to start it. The car wouldn't attempt to start. I tried the remote from the 2000 and it didn't work. I took the remote from the 1999 and the doors would unlock. I swapped the body control module from the 2000 into my 1999. The remote from the 2000 will lock/unlock the car. I then tried to start with the key from the 2000 and the motor cranks, but it sounds like I'm getting no spark. I noticed my security light is staying on now. Anyone have any thoughts? Is there a security module I need to take from the 2000 and put into my 1999?
Old Sep 15, 2016 | 10:53 AM
kswLS1's Avatar
You need to disable VATS with a tuner like EFI, HP, etc.
Old Sep 17, 2016 | 06:48 PM
SlasherVRGR's Avatar
Or if you won't have the cash for a tune, or software, you can bypass vats with a resistor. You'll need to measure the resistor on the key for the car the pcm came from. There's write ups for it I'm positive.
