Proper belt tension?
Old Sep 12, 2016 | 11:45 AM
Forcefed86's Avatar
Default Proper belt tension?
Where are the lines on the typical LS tensioner supposed to be? Is this too tight? Thinking about moving up to next belt size.
This is a custom setup/routing so I don't have a "stock spec" to go from.
Thanks
Old Sep 12, 2016 | 12:32 PM
usnfenix's Avatar
seeing as how you have a custom setup I don't think any of us can accurately answer this for you.
IMO if its tight and not slipping......don't fix it.
Old Sep 12, 2016 | 01:07 PM
Forcefed86's Avatar
It looks like go/no-go markings on the tensioner? i was assuming someone with a stock vehicle might have noted the position of the markings with a new belt.
Old Sep 12, 2016 | 03:04 PM
67Lark's Avatar
Looks like there is a little bit of room there but once the engine is running that belt deflects a little and will pull that tensioner tighter.
Like you had said it would be nice to see how a stock setup fits with tensioner.
Old Sep 12, 2016 | 03:11 PM
usnfenix's Avatar
if this is still needed ill post what mine looks like when I get home.
Old Sep 12, 2016 | 03:19 PM
Forcefed86's Avatar
That would be great, thanks…
