Water pump recommendations
Any pros to going with a different pump? Or would the stock pump perform just as well as any "upgrades"?
Thanks!
Mechanicals are are more than adequate on the street, only
advantage of the electrical is to turn it on between rounds for
extra cooling. Mechanicals actually flow a lot more than electricals and don't use a lot of hp to turn. Electric pumps cause a drain on the electrical system and alot of people don't realize that electrical drains cause higher alternator loads and require more HP to turn out the amperage. Disconnecting the alternator at the strip is worth a solid 10hp.
This design was created for GN West NASCAR racing.
MY reason is the position of the Water Inlet, which IS much different.
This position allows for a more "normal" radiator design for use in an Engine Swap requirement.
This pump features greater flow and pressure.
The thermostat is at the top, another feature.
Lance
