Differences in starters for ls1
Old Oct 25, 2016 | 07:25 PM
vroque210's Avatar
Default Differences in starters for ls1
I recently did a t56 swap on an 04 5.3 and now I have developed starter issues. Before I did the swap it would start up perfectly fine even on a low charged battery. I compared the flywheel to the pressure plate before starting the install after I removed the 4l60e and all the teeth matched up fine. Is there supposed to be a higher torque starter that is required when you swap the t56? It is intermittent and hard to pinpoint why it happens but when it does it just clicks over and over like a starter going bad. On other days it start's right up.....changed the starter and is still doing the same thing. I used an 04 truck starter. Anyone have suggestions?
Old Oct 25, 2016 | 07:49 PM
slogo's Avatar
All the wire connections good? Did you loosen a ground strap?
Sounds electrical to me.
Old Oct 25, 2016 | 10:49 PM
01ssreda4's Avatar
Yep, starters are the same between transmissions.
Old Oct 26, 2016 | 05:45 PM
vroque210's Avatar
see that's what I thought. I did move the battery from behind my seat to the back in the truck bed and I'm wondering if having it sit in the back inside of a black marine box is affecting it as well. I read somewhere too that the 6.0 starter had a little more torque. I am having my battery charged right now anyways and took the new starter back cause I highly doubt it was that anyways. Not wasting 175 bucks for something that isn't even wrong. I didn't mess with any wires either by the way
Old Oct 26, 2016 | 11:02 PM
.boB's Avatar
Most likely you have a poor connection somewhere, or didn't use a heavy enough cable. Moving the battery further from the starter requires a heavier cable. Be sure to check your ground connections.
Old Oct 27, 2016 | 08:25 PM
vroque210's Avatar
gotcha. Yeah I am leaning more towards the cable's I used and how long theyou actually are. It's about 6ft from the starter. I think I'm just moving the battery back to behind the seat
Old Nov 3, 2016 | 05:43 PM
vroque210's Avatar
Well after moving my battery behind my seat I ended up with the same issue. Turns out after checking all my grounds that one ground was corroded out and hanging on by a few little wires. Replaced that and added 2 more ground and she fires right up everytime. Thanks for the help everyone
