GM Performance Accessory Fit in 3rd Gen
Old Nov 22, 2016 | 10:07 PM
84xc's Avatar
Default GM Performance Accessory Fit in 3rd Gen
Hello, has anyone tried the GM Performance serpentine kit with a/c in a 3rd gen F body? The part number is 19155066 and they label it as a CTSV kit or F-body kit (assuming that they mean 5th gen). From the dimensions shown it looks like the only problem will be the a/c compressor on the k member, which I will either notch or more likely just run an aftermarket tubular k member if so. I would just run 4th gen accessories but where I live they are impossible to come by and this kit seems to be the best option. And yes, I did try searching but it appears not too many people seem to use GM's kit? Is there a reason for this?
Old Nov 23, 2016 | 03:27 PM
99 Black Bird T/A's Avatar
With my 3rd gen Camaro we used the 4th gen accessories. It was less expensive. I also deleted AC to reduce weight. Aftermarket k can work or notching stock k. Hawks Motorsports has a special bracket for adapting 3rd gen AC compressor to LS1 if i recall correctly.
Old Nov 26, 2016 | 10:33 PM
customblackbird's Avatar
I run the stock 5.3 truck accessories on my 87 TA. I Don't run the AC compressor though due to a supercharger. I do however run a race craft moly Member but since I don't run the stock AC I can't comment. Usually you need to notch the stock Member for the low mount AC compressor. Or you can swap to a high mount. Only issue with the truck accessories is I needed to swap to a smaller PS pulley to clear the PS box. I had maybe 1/8" clearance with stock pulley... a smaller 5" gave me a lot more room. This is with the motor in the stock SBC location... could have moved it farther back but then I would need to shorted my DS so no thanks lol.
